Flash Setup
I would like to get some input from Flash pilots. What is your Setup. We have had 4 Flashs at our field.
I am setup at the forward cg makr of 370. I need a small amoutn of elevator trim for straight and level on third to half throttle flight. At full throttle it doesn't need any trim and it is mixed out with a throttle to E mix. When I put full flaps on I need the down elevator mixed in, about 1/8th". This is what the about what the book called for. With this setting I can fly hands off with full flaps. KE rudder mix is 5% R to A same direction.
The other three at our field didn't require any up elevator trim for level flight. And there Flap mix needs to be up E not down E. All of our cgs are in the same area.
What is your Flash setup like?
