RE: Gluing foam
I've used foam safe CA, actually just odorless CA, and it works, but the stuff is brittle. Repairs with the UHU glue tend to hold up better over time. It's cheaper too. Try it, you will probably like it better than CA unless you need an instant set. UHU will take a few minutes, maybe 10 to 15 min to be set well enough to use.
