RCU Forums - View Single Post - Vacuum chamber to remove bubbles
Old 04-13-2003 | 10:44 AM
Flyingmike-inactive
Default Vacuum chamber to remove bubbles
Hi
I think your right!!!!
However, I do use a surface coat and this does give a good finish, but the things I make are usually clear so you can see the carbon weave, unfortunately you can also see the air bubbles between the weave. and these are what I`m trying to get remove, I`m going to try again today with a lighter cloth.
Mike
