ORIGINAL: Zeeb
Hmm...
I was thinking I'd read that the offset on the SWB was 2 1/2 degrees right and thought that would be a good starting place. Neither of you wound up putting any up thrust on the engine like the manual recommends that 1/2 degree up?
We did put the upthrust in. I forget how many spacers were used to reach the correct distance to the cowl though. I can check on that when I go back out to my "Hanger" and will try to take a pic for you.
Doug
