ORIGINAL: calvino
ORIGINAL: So Cal Nitro Basher
Okay i NEEEEDD some help. My friends rc18mt is all wierd right now and i need to know how to reset the speed control, i called accociated and they told me and i couldnt rite it down fast enough, so now i dont know how to do it. And the manual dont say.... So somebody please tell me how to do this!!!
thanx Aaron
turn on the truck
then hold like a small allenwrench... on the SET button
keep holding it on there until BOTH lights flash at the same time
then leave the xmitter on NEUTRAL (don't touch it at all), press SET, the light (LED) is
now GREEN
pull the tx back to full "forwards" and press the button, the light wil turn RED
then push the xmitter to full "brake" and press the SET button, the lights should flash simultaneously 3x, the ESC is programed
if you think, oh no, I messed up, UNPLUG the power for over 10 seconds, and try again.
hope that helps
Awseome! Thanks alot. Ya my friends rc was bieng wird and wouldnt go when you would hit the throttle, but would go in reverse full throttle until you hit the throttle forward again. I will call him and tell him what to do and see what happens. Thanks again.
