RCU Forums - View Single Post - Flying wire/Guide wire for strength?
Old 04-09-2003 | 01:19 AM
Paul Cataldo
My Feedback: (10)
Default Flying wire/Guide wire for strength?
Thanks fellas. Good info.
One last thing. If I were to install these metal wires on a larger scale plane, would it be a bad idea to run my antenna wire up to the vertical stab like I normally do? Would interferance be a problem. I normally like to run my antenna up to the vertical stab to keep it away from the ground while on the runway. I've never liked running it up under the aircraft, but I also don't want any interference. I've never had interference problems, but I've heard of guide wires on the stabs causing interference. Thanks.
