RE: sts 28 starting problems
Are you running 30% with the 4mm shim set up? If so have you pulled the head and check out the top of the piston? I will be starting next year with a new Hyper 8.5 with a new STS D21T MKII. I have one STS D21B with well over 5 gallons on it still running fine.
