Rudder/Elevator Pull Pull Systems
Guys,
I am beginning to see that I will need to use these systems as I get into bigger planes.
Could someone please post some pics or explain how these systems work in detail.
I saw a listing for the elevator servo horn on Central Hobbies that is designed for an elevator pull pull system? I just can't figure out how it works.
I've always used a y shaped pushrod for the elevator, but could use some help understanding the other method of choice.
I believe after you guys explain this to me, I will pretty much have ARF building understood for the most part. Thanks again for everyones help on my other threads.
