RCU Forums - View Single Post - Length of prop from the hull, what difference does it make?
Old 12-28-2007 | 10:41 AM
Ron Olson's Avatar
Ron Olson
Default RE: Length of prop from the hull, what difference does it make?
What I've found out so far is that the strut needs to be higher the further out the strut or stinger is. The water is lower closer ot the transom and higher the more it is away from the boat.
We're discussing this elsewhere, I'll see if I can find you a link to the thread.
