RE: HL Pershing Problems
When it fell, did it, by any chance, impact on the side that ends up being the inside of the circle you get when trying to go forward??
If so, you busted the idler or jammed up the gear box on that side. If the driver board was the problem, it wouldn't work right in reverse.
Good luck,
Splat
