RCU Forums - View Single Post - Supertigre Engine issues
Old 12-29-2007 | 12:05 AM
OzMo's Avatar
OzMo
Default RE: Supertigre Engine issues
I was reading this and I assume the fuel is good. The worst engine day I ever had was caused by a bad gallon of fuel. watch for air bubbles in the fuel line. I second the opinion to redo the tank assembly. good luck[8D] make sure the carb seal is good as well as back plate and head. the stuff you will learn solving his problem will give you skills you will never loose so keep smiling
