RE: servo torque requirements
Hi Bubbagates, also do you make it a point to position the (aileron forexample) control horns on the elevator, so that the pushrod is at an angle when at neutral, but a straight shot to the servo horn at full deflection?
I think that helps to maximize the holding power and minimize any pushrod flex. (because at neutral there is not nearly as much load on the system as at full deflection.
Ernie
