RE: FLy Eagle Jet Models
Hi Mike i am glad that you have got them to work,i tried allways but was not convinced.What measurement did you use the web site is not very clear i used 33mm oneway and 24mm the other was this correct?i had to redrill mine so the nipples faced in towards the centre of fuse. i am fitting a Wren Supersport 18lbs thrust with an exhaust duct regards Keith
