RCU Forums - View Single Post - The Long Awaited Ultra Sport 60 Build Thread
Old 12-29-2007 | 04:45 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: The Long Awaited Ultra Sport 60 Build Thread
Now the front-bottom sheeting is glued to the leading edge and the forward edges of the ribs.
While the LE dried, I dampened the outside of the sheeting with water and let it sit for a while before continuing.
Once the sheeting was attached to the rest of the rib fronts and spar, I took advantage of the open top to reinforce the glue joints. Too bad you can't do this to the sheeting on the top side too!
ID:	836643   Click image for larger version
