RE: New Rigger setup
I have no had personally any experience with the boat. But i can tell you it is a very very good little rigger.
as for adjustments I'm not to sure like i said before I don't own one.
when u have the boat check all the measurements to make sure the pack will fit in the hull. 2170 Mah should be good, but a bit more like 4000 would be better
