RE: can i handle this?
That would be a good second plane. Like someone said before, stick with low rates and get used to the plane then slowly work your into high rates. Do new manuevers at about 3 mistakes high first until you get them under control then work you way down to the deck.
Personally I would stay away from scale type planes such as warbird and jet types. They land hotter and stall at higher speeds. If your not prepared to correct it without thinking, then the plane soon becomes a lawn dart...Save scales planes and Jet types for your third plane...
Good luck...
LD
