RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 12-29-2007 | 08:42 PM
  #5472
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
It's suggested to use a Teflon Spray for the rotor head, due to the fact of the rubber, that oil may soften the "O-Ring" in the rotor head.
WD-40 won't due, it's not a lubricant, it's a penetrating fluid and water displacement agent. Hmmmm, however, I've used Tru-Oil and never had a problem with "O-Rings" getting soft. Sewing machine oil, 3n1 oil, something light. Before you oil stuff up. Did you move the flybar up and down to see if it's binding or has alot of resistance. Lubing up, still wouldn't be a bad idea. To do it 100% properly, you have to remove the blades and remove the grips. Cuz, there is a bearing and a thrust washer inside the grip.
Or you can cheat the system and apply the oil a little heavy, move things around and wipe off the excess with a cotton ball or Q-tip.
I never do that!!!!(Yes, I do) If you don't take the rotor head assembly apart, just oil, generously, where the blade grip contacts the main rotor head. And Dribble , some into the blade grip, where the blade grip nut is.
Dave / Choppersrule
ORIGINAL: Barrrick
NOW here is where I begin to PAY for not doing the "mechanics" of the helicopters. You mention ' LUBE " ok then : LUBRICATE WHAT AND WHERE AND WHAT WITH ?????
Sorry for the bother, but I will DO WHAT YOU SAY
RICK
