RCU Forums - View Single Post - Blade CX2 spining left -
Old 12-29-2007 | 11:45 PM
Wolfpackin's Avatar
Wolfpackin
Default RE: Blade CX2 spining left -
I would at least have the replacement outer shaft on hand in case you lose another tooth or the problem reappears.
Also, another thing to note is that if you tighten the two upper screws of the lower head too tightly they will rub on the inner shaft causing binding on either or both of the shafts.
