RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 12-30-2007 | 01:37 AM
  #1912
mikenlapaz
Default RE: gas fuel with glo plug no ignition
I have the original prop adapter that I bought from Ken Lambert that was to be used with the flywheel. What will I need for a prop adapter after I remove the flywheel? My prop hub adapter ( to be used with the flywheel)will no longer work will it? Anybody got one that will work they want to trade?
Why not fire it up with the flywheel in place and a prop. Make sure you are happy and then either cut that flywheel center out with a hole saw and then true it up and us it. or get another flywheel and chop it up.
Matching the taper on the shaft is the big obstacle.
