RE: gas fuel with glo plug no ignition
but we do need to add the 1 bad thing about gas/glow. You need to lock down the prop hub. The engine will run back words and though the prop hub off. It did it to me. and it hurts. what I did was drill a hole in the side of the prop hub and tap it. Put in a set screw. Lock tite works too.
av8tor1977
What do you do to start your engines so they do not run back words. (I do not care if my spelling is wrong) lol
Paul
