RE: Glitches, help needed
[:@]42 degrees C outside today so being 1 of 3 fools out at the field I setup the plane. Battled like crazy to get the motor started and between blinks of sweat noticed the fuel tube loop on the carby had kinked over one of the standoffs. Anyhow.........
I think I've traced A problem to the Emcotec DPSI micro ignition switch. With it totally unplugged from the system and a spare 1000 mHa battery plugged into my mates borrowed Ignition. I can get about 56 slightly longer than normal paces range before all the surfaces start to glitch a bit. I finger to the TX arial stops it. 56 paces to me is longer than 100 feet which is the recommended range check distance, not so ?
My rudder servo still jitters at varying distances but only about 1cm travel max.
So I recon I need to swop my ignition cut off and the ignition.
