RCU Forums - View Single Post - accu cycle elite--having problems.
Old 12-30-2007 | 08:46 PM
acarter's Avatar
acarter
Default RE: accu cycle elite--haveing problems.
ORIGINAL: goirish
Just seems like the instructions are many--all I want to do is charge and cycle my batteries.
I myself just got the accu cycle about two months ago, It is a litlle complicated at first. I'm still learning!
As for the transmitter. All current futaba radios have a diode. So the only charger you can use is the wall wart. Unless you bypass the diode. The only problem I see if you do it yourself is that it might void the warranty.
Good luck,
Austin
