RCU Forums - View Single Post - 3D Hot Hots Build
Old 12-31-2007 | 03:03 AM
kbear's Avatar
kbear
Default RE: 3D Hot Hots Build
A few more photos.
The area below the upper LG mount is filled with balsa and sanded to match the fuse. Then the Lower LG mount is added. This is one of the pieces that was missing from the kit. I still have not got around to contacting Steve so I just made the part myself out of 1/8" birch ply.
Glued the nose former on and filled and sanded some gaps with balsa.
The tail group is standard stick building so I won't go into great detail. After test fitting the HS I did find an answer to my earlier question.
The HS sits far enough forward that is leaves a gap at the end. I decided to split the elevator halves and us a music wire joiner. What size Music wire should I use? I was thinking 1/8" in, but that seems a bit large. 3/32 doesn't seem strong enough. Help me out here. The elevators are pretty large and I don't want them to twist under load.
I added a base piece to the VS and glued it to the HS with a couple of support block. The whole assembly slid into the tail. I won't glue it in until I get the wing built so I can make sure it all lines up correctly. I extended the TE of the VS and will glue it to the tail when I mount it. Anyone have an opinion on my solution?
I have to mount the servo rails in the tail and finish the bottom sheeting. I won't sheet the nose until I get the engine mount on so I can still get to the back of the fire wall for the blind nuts. I ordered a 5060 Dave Brown mount as stated in the article, but the fire wall is actually drilled for a 4650 which is what I will use. If you want to see larger Photos you can find them [link=http://www.putfile.com/papabearspad/images/167765]Here[/link]
