RCU Forums - View Single Post - accu cycle elite--having problems.
Old 12-31-2007 | 09:16 AM
acarter's Avatar
acarter
Default RE: accu cycle elite--haveing problems.
ORIGINAL: Geardaddys
The Accu-Cycle Elite WILL charge a futaba Radio with the battery in the radio.. It will not however discharge or cycle your battery. I'm not sure if this is true for every futaba radio ever made, but both of mine (9C and a cheap 4 channel) both have the diode.. My cynical side thinks maybe they do this to keep you from cycling the battery thus forking over another 35 dollars for a new battery after a few years? Who knows, but I have been using my Accucycle for going on 3 years now to charge these radios..
If ya'll need help with the charger let me know what radio/pack you have and I will post settings that will work for the battery.. It's really very simple..
GD
Actually the accu cycle won't charge the through the transmitter. It's a peak charger so it still needs input from the battery, which means it will do a little discharge to see how the battery is doing. As for the polarity correction. The accu cycle knows when the polarity is backwards and won't charge. So there in no risk of reversing polarity.
Austin
