RCU Forums - View Single Post - Dualsky 6360 wots watt ??
Old 12-31-2007 | 01:52 PM
OhD
Default RE: Dualsky 6360 wots watt ??
ORIGINAL: serious power
The specified max input power for this motor is 2450W, on the Dualsky web site. The heading on the spec,, sheet says ;'Max Input Power @ 15S '. Can anyone explain this ??
Brian
The way I read the data sheets it says you can go up to 10S not 15S. 2450 divided by 35 (10s under load) equals 70 Amps. I'm sure this is true only if the motor is well cooled.
Jim O
