ORIGINAL: thirdkid
love the ball brg thing. Thats exactly what it seemed like. Are any of the free sims any good?
the free sims are ok but not as realistic as the better ones. the one thing you should be able to do is turn on the exp function on the radio, try it at 50 and see if that makes a difference. exp reduces the amount of servo movement near the center but does not reduce the total throw of the servo.
so basically, instead of a straight line relationship between moving the stick and servo movement, you have a curve which starts out shallow and turns upwards and ends at the same point.
