RCU Forums - View Single Post - TIGER 1 Build some new twists
Old 01-01-2008 | 02:00 AM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: TIGER 1 Build some new twists
Its time to post another update!
I have wired up the two batteries, using W.S. Dean connectors! I am installing a single charge port for the two batteries! I have a mini switchboard designed to select either battery for charge or either battery for use as the tanks power! I am using a 3-pole switch to initiate the charge port and select one battery at a time to be charged! I am also using the Heng Long on/off switch as overall power kill, and a separate 3 pole switch that will select which battery will be initiated to power the tank, the middle pole on this switch is also an off switch! This is kind of over kill, but at the same time if I get in a hurry at a battle, I don’t want to plug the charge port in by mistake when the power is still on going to the tanks, ESC board!
I have a few pictures of the head light covers that I have crafted myself along with the hatch, it looks rough now but after it gets painted its not too bad, that comes later! The tank is coming together, I am still deciding on what ESC board is going to run this tank??
the Blitz[sm=shades_smile.gif]
ID:	839059   Click image for larger version
ID:	839060   Click image for larger version
ID:	839061   Click image for larger version
ID:	839062   Click image for larger version
ID:	839063   Click image for larger version
ID:	839064   Click image for larger version
ID:	839065   Click image for larger version
