RE: GasZenoah 26 engine in plane causing rf glitching HELP!!!
Glad you got it fixed... I had a similar problem with a G20 ei and found the problem to be running the antenna wire too close to the solid wire sheathed push rods of an Ultra Stick Lite. After moving the antenna to a tip of the horizontal stab... the problem was solved.
