RCU Forums - View Single Post - hitec rx and fut tx compatable?
Old 01-01-2008 | 10:57 PM
amdhotprocessor's Avatar
amdhotprocessor
Default hitec rx and fut tx compatable?
Hi all, I have a CMP edge 540 on the way and im getting my stuff together to get ready to install.
I have a futaba tx on ch 41, and I have been using my rx( the futaba one) in my pulse.
Now im not sure if the upper and lower channel deal with futaba is only in the rx or if it is in the tx too.
So... I have a rx a friend has given me, A very nice new hitec supreme 8ch
The rx has a ch29 crystal in it. So of course i need to change the channel
But On the rx it does have a small green oval over the channel sticker that says "FUT"
so I asked the LHS owner and he tells me that if I didnt have a fut tx i could use it but futaba cant be used with anything but futaba because of the upper and lower channel ranges.
I thought that you had to use a high or low when using the futaba RX but the tx is a non issue.
So wouldnt i just change the rx crystal and use it? What type of crystal will i want to use?
I thought I would use a hitec crystal in it but I want to make sure before i get one.
My tx is a futaba T6eax or something close to that, Its a 6ch computer radio
