RCU Forums - View Single Post - Eureka Banshee Build Thread
Old 01-01-2008 | 10:58 PM
  #59
Free Bird
Default RE: Eureka Banshee Build Thread
Here's where I changed the L/E a little. The plans have you butt join the L/E at the center, I changed this to a scarf joint as it's a little stronger and easier to make a perfect joint. The L/E is sanded down so its flush with the opposite L/E and then using a razor plane, the excess stock is removed from the top and bottom and then sanded flush with the sheeting. The other L/E is glued in place and the same process is repeated. The end result is perfect.
ID:	839966   Click image for larger version
ID:	839967   Click image for larger version
ID:	839968   Click image for larger version
ID:	839969   Click image for larger version
