RCU Forums - View Single Post - Switching Fuel, need help!
Old 01-02-2008 | 01:53 AM
d16z6
Default RE: Switching Fuel, need help!
ORIGINAL: nitro_addict218
I am running the same nitro %, but the oil content is alot lower. I believe they said i was using 30%. I also changed the glow plugs before i switched the fuels. I guess I will switch back to using trinity today and see if I can get it to work. It is very hard to tune it to this fuel because I guess my engine is used to having such a high oil content.
Umm... if anything a fuel with less oil content will allow an engine to be able to run richer w/o dying. Basically it should be a wider window of easier tuning. This is also because now the difference in oil is replaced with methanol/nitro which are the power producing agents.
