RCU Forums - View Single Post - Bobcat elevator mix while landing
Old 01-02-2008 | 07:20 AM
jetflierinca
Default RE: Bobcat elevator mix while landing
I will slow down more and I'm sure that will help. But the point about adding UP when you drop flaps with or without crow is what does not make sence. If flaps make the plane climb why would you want to add more up elevator in the mix? Sounds to me like it should be DOWN. Thanks for all the input!!
