Hi Gerhard,
Happy New Year
I tried Sync-ing .
I set up one channel only for aileron (Master&Slave Group 1 and 2)
When I synched Master&Slave Group 1 the servos paused with some tiny adjustment on both travel ends (I suppose the servos are trying to match the travel) >>> I guess this is the way it suppose to happen...
However on the Master&Slave Group 2 the servos travelled without pausing on both travel ends.
For curiosity I switched the position of the Master&Slave combination from left aileron to the right aileron and vice versa.
Then I tried synching again. The reverse situation now happened, that is the pause now is happening on the Master&Slave of Group 2 !
Q: Is this because the two servos travel combination on one side of the aileron has more equal travel match ? or what is going on?
Your advice is truly appreciated.
Cheers
Aris Kamdani
