RE: TWO separate engine problems
Once you get the GMS running right, you'll love it.
It's a strong reliable engine, but there are a few things you need to be aware of...
e.g.
- The cap screws WILL come loose after the first few runs. They'll need tightening.
- You need to be careful with those cardboard "rings" they use on the fittings, these will cause the fitting to loosen or leak over time. Check them periodically and be careful NOT to overtighten as they are quite easy to strip.
- If you have the remote high speed needle, check it too for looseness, and watch for a hairline crack on the provided HS to carb line... I'd replace it ASAP with other tubing.
- Make sure you clamp the carb DOWN hard when you screw it in place to form a good seal.
- If running inverted, a longer "F" plug is a good idea.
- Try to get a temperature meter and watch the head temp. You'll have the engine adecuately tuned if it hits around 280F or so on the ground uncovered, but does NOT go to say 380-400F which is too hot.
- The engine doesn't really come into it's own until you've run a couple of gallons through it.
- Keep your first flights around 5 minutes as typically you'll have the engine so rich that it will run out of fuel VERY quickly. It may surprise you how fast it uses fuel until it is tuned well. Once tuned it does well with fuel consumption.
