RCU Forums - View Single Post - TWO separate engine problems
Old 01-02-2008 | 01:39 PM
shd3920
Default RE: TWO separate engine problems
Will simply heating the area with heat gun work or does it really need to be started to loosen it up?
ORIGINAL: opjose
Do this before you send it out.
Put the prop back on the GMS engine.
Remove the glow plug and put a drop or two of fuel into the cylinder. Leave the glow plug off.
Now heat the cylinder head until it is almost too hot to touch with a heat gun.
Crank it over.
I am worried about heating it up with a heat gun with fuel in it, I'm liable to blow it up
