RE: Eaglet 50 and OS LA15
Actually, at idle the prop will slow down the plane because the prop will be moving slower than what the plane is. You can actually create a brake to slow the plane down with certain types/brands of props.
A heavier engine can make a difference in the balance of the plane. You might have to add a little bit of weight to the tail of the plane to get it to balance properly with the bigger engine.
Ken
