ORIGINAL: rcmxsports
want run tirews that do not baloon out so much which model bransds or trick to keep them from doing it.
Depends on what you are doing with your truggy. If you are racing I would use 6-10k silicone diff lube. If you are bashing and are not that concerned about loosing a little turn in. Lock it up with 30k diff lube.
