RCU Forums - View Single Post - Monokote on Monokote
Old 04-12-2003 | 01:36 AM
Charlie P.'s Avatar
Charlie P.
Default Monokote on Monokote
I am currently putting black Monokote stripes over orange using the trim solvent and I have black ooze that's a pain in the arse. Squeeging out the bubbles also forces black ooze out and onto everything. I have to dip a q-tip in the solvent after the stripes have set overnight and wet the smudges and then wipe the area with a tissue. Another problem with the solvent is that once set in place it is not possible to slide the stripes as it is with decals set using Windex. And, if you squeege too much you can force all of the color out, leaving a clear spot where the under color shows through.
It took me a while to get a feel for using it but now I am getting good adhesion. I'm going back to Windex for the larger areas.
