Monokote on Monokote
One thing to note about trim solvent is that they are not all the same! The "No Heat" brand is a very volatile solvent, and after it evaporates, it's gone gone (won't stick anything to anything). As a result, you have to work really fast, which is not always a good thing. The Monokote trim solvent has stuff in it that doesn't evaporate as fast, and as a result, you can use it very sparingly, and pretty much take your time. It will still stick after it appears to have evaporated.
