RCU Forums - View Single Post - soldering connectors?
Old 04-10-2003 | 03:37 PM
Kaos Rulz
Default soldering connectors?
I've found if you drill a tiny (#60 - #70) hole at the top of the barrel that the rod slides into, this will aid solder wicking as it flows to the heat, and acts as a window that will fill with solder when the barrel is full. (ref Minn's graph, the hole will be about where his "heat here" arrow is pointing)
