soldering connectors?
If you use acid rather than rosin, be sure to clean the part very well when you're finished. Otherwise it will corrode and eventually fail. Rosin is hard to use on music wire, but it can be done. As has been mentioned, you have to clean the part first and maybe use some fine sandpaper to give the music wire a little tooth.
