RCU Forums - View Single Post - Lanier Citabria help...
Old 05-02-2003 | 10:07 PM
RCPROPSNAPPER
My Feedback: (22)
Default Lanier Citabria Struts
Hey guys,
I just finished putting this model together. I wasn't impressed
with manual for this arf. I had to look at those struts awhile before I figured them out. I'll try to help. What you have to do,is
mount the hardware you used for the control horns on each
side of the fuselage, top and bottom. On the botton, the strut
wire attaches by pressing in the wire where it bends 90 degrees.
The top part of the struts attach with clevises. So, you need two
attach points on the top of the wing on each side and one on the bottom on each side. I would draw it out for you but I don't know how to post a picture here. I assume you can figure out the
mount locations but if you need more help, post again here. I
hope I didn't confuse you more than you are already.
Good luck,
RCPROPSNAPPER
