RCU Forums - View Single Post - Is there a good way to adjust CG at the field?
Old 01-03-2008 | 09:30 AM
goirish's Avatar
goirish
Default RE: Is there a good way to adjust CG at the field?
You can use split sinkers and tape them on where you think they should be. You can move the tape in or out, add or take-away. When you get it where you want it then you can make the final adjustment back at the shop.
