RCU Forums - View Single Post - Is there a good way to adjust CG at the field?
Old 01-03-2008 | 12:29 PM
fozjared
Default RE: Is there a good way to adjust CG at the field?
yes stick on weights are the easiest thing, or you can get an extension and just move your battery, that is if you haven't already moved it as far as possible.. the plane already has to fly with the weight of the battery though, why not utilize that weight instead of adding more weight!?
