RCU Forums - View Single Post - hybrid wing problem
Old 01-03-2008 | 08:59 PM
outssider
My Feedback: (23)
Default RE: hybrid wing problem
I figured out what is not right. As you can see from the picture below, the rib is not straight, it is actually a little concaved. all the other ribs are straight at this same area. I can add a bit of balsa to correct this on both sides on both ribs (both R2 ribs are bowed in like this. should i make the correction or is it supposed to be bowed in as the picture indicates ????
