RCU Forums - View Single Post - Throttle Arm
Thread: Throttle Arm
Old 01-03-2008 | 09:23 PM
enduser
Default RE: Throttle Arm
If you have problems starting your engine because the pull start is hard to pull its probably because its flooded and you have to yank really hard on it which eventually will break something. What I do is to loosen the glow plug till the pull start is easy to pull. I then put on the glow plug igniter and pull start the engine. After its running I quickly tighten up the glow plug.
