RCU Forums - View Single Post - H9 TCraft Elevator Probs
Old 04-10-2003 | 03:14 PM
Schubox
Default H9 TCraft Elevator Probs
Hey Todd, talked to you awhile back. How's the isnstallation of the 180 going. As far as the elevator set up goes I would recomend you change something now before you regret it, like the dual servo set up with nyrods or sulivans. I used their set up only instead of cutting the 4-40 to 8 1/2 in I left them full length, and cut the single servo rod to the desired length I needed. Seems to work just fine with a hite625. Hope you are ready to handle the 180, I flew mine two days ago , and the plane seems to have about twice as much power as it needs. Takes off at 1/4 throttle. Almost S@#$ my pants when she went up. Another suggestin is if you have premixes in your radio, you will need to mix a little rudder with ailerons. This is a very large bird and she tends to slide through turns without rudder. You probaly already anticipated this, but just thought I'd add my 2 cents.
Jason
