Best smaller gas engine to replace 1.2 4 stroke
WreckRman2,
Are you saying the power to weight ratio is poor until you get to the larger gas engines? I have had bad luck with 4 strokes, the two I have had were so finicky and a pain to maintain. I know other people say the have not had a problem. I can replace the 1.2 FS with a much cheaper good motor like an ST 90 that will pull my 8 lb plane around just fine. I just wanted to try the convience, lack of mess and lower cost of gas.
