The Goods:
3R CF Chassis
also:
10.5 BL novak system
GPM Alum lower front amrs
GPM Alum lower rear arms
Square RC one way shaft
3pm Futaba 2.4G FASST RX/TX
on with the pics
Ok well the first pics are of the Chassis and the Dif housing and other parts
This is a picture of the CF chassis drying after i gave a coat of Crazy Glue to all the exposed sides, even the counter sunk screws and what not
the only thing that was odd was it seems the front dif housing where the drive outshaft connects to center one way shaft is very long and deep, much more hollow then the stock one, and the one stock bearing was allowing to much play in the out putshaft, so i went out and bought another bearing so it has 2 and now it sits nice and snug. well on with the pics
i still have to retune it for drifting as far as camber and droop but the hard work is done
i know the bumper is on backwards, it wouldnt fit tight any other way
