RCU Forums - View Single Post - B400/DX6i: Adding Second Model & Binding?
Old 01-04-2008 | 09:19 PM
choppersrule
Default RE: B400/DX6i: Adding Second Model & Binding?
Wolf,
I'm not a wiz, but write down the original setting for the B400. Set up model two and rebind. Can't hurt to try. I do know that you have to bind with each model. That's how the TX knows where the RX is and its mystical internal settings.
You may be the first to try this, let us all know.
Dave / Choppersrule
ORIGINAL: Wolfpackin
I would like to add another Blade 400 model into my DX6i.
Same heli just another TX version so I can change settings and compare them to the original setup.
I added the second model with the setup changes I wanted but the ESC won't arm with it.
Do I need to bind this new model to the RX and if so will the original model keep its bind?
I'd like it if both stay binded so I can switch back and forth, make comparisons, without having to bind every time.
I'm hoping anyone with a DX6, DX6i or DX7 can answer this.
Thanks.
